Posted August 9, 2013 I run an eyefinity monitor set up with these specs: i7 980X 12GB DDR3 Dominator Asus Sabertooth x58 x2 GTX 580's 120GB Intel SSD They run fine and I can play all my games fine but I run into frame drops a fair bit, I have both the 580's on the sabertooth x16 slots. the top card really doesn't have much room to breath but if that was really an issue motherboard manufacturers wouldn't put pcie slots so close together. As I said I can run games but I do receive some really bad frame drops. (I am not running games in eyefinity), for example SimCity that seems simple game I see people streaming, recording and playing it fine with no frame issues at all. Do I need to invest in a new motherboard so the cards can breath? Link to comment https://linustechtips.com/topic/44387-performance-opinions-and-temps/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2013 i wouldnt. the only thing i would get is maybe a custom loop for wc. thats a great cpu and with wc you can really bring out its potential Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2iFiio E10 Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP Link to comment https://linustechtips.com/topic/44387-performance-opinions-and-temps/#findComment-581955 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2013 You shouldn't have too, what temperatures are your GPU's hitting? CPU: Intel Core i5 2550K @ 4GHz | Cooler: Gelid Tranquillo Rev. 2 | Mobo: Gigabyte GA-Z68AP-D3GPU: XFX 1GB HD6850 OC'd | SSD: OCZ Agility 3 60GB | HDD: Samsung 500GB | PSU: Corsair HX520W | Case: Zalman Z11+ Link to comment https://linustechtips.com/topic/44387-performance-opinions-and-temps/#findComment-581977 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2013 Stick with the motherboard you have. If the card is overheating, just get one of those aftermarket GPU coolers. CPU: AMD 3950x Mobo: MSI B550 RAM: 32GB DDR4 GPU: Asus 3080 Strix PSU: Superflower Leadex 3 720w Case: BeQuiet 500DX Storage: 2TB SSD + 4TB HDD Audio: SMSL 793ii -> HiFiman HE-400 + Mission MS-50 Speakers Link to comment https://linustechtips.com/topic/44387-performance-opinions-and-temps/#findComment-581983 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2013 i would wait and buy 9970 when it comes. Error 709: Walrus on the road! My build log: http://linustechtips.com/main/topic/131216-the-small-white-p-node-304-build http://linustechtips.com/main/topic/190057-build-the-large-p/ Link to comment https://linustechtips.com/topic/44387-performance-opinions-and-temps/#findComment-581994 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2013 Author You shouldn't have too, what temperatures are your GPU's hitting? top gpu about 37 and bottom around 29 idle and can get hot while gaming but I usually crank up the fans with msi afterburner before gaming Link to comment https://linustechtips.com/topic/44387-performance-opinions-and-temps/#findComment-582057 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2013 I'm thinking that your cards are hitting their thermal thresholds, so then they're decreasing performance to maintain a safer temperature, hence the sudden frame drops. Do you know roughly what temps your cards are hitting while gaming for an hour or two? Also, how well is your case ventilated? CPU: Intel Core i5 2550K @ 4GHz | Cooler: Gelid Tranquillo Rev. 2 | Mobo: Gigabyte GA-Z68AP-D3GPU: XFX 1GB HD6850 OC'd | SSD: OCZ Agility 3 60GB | HDD: Samsung 500GB | PSU: Corsair HX520W | Case: Zalman Z11+ Link to comment https://linustechtips.com/topic/44387-performance-opinions-and-temps/#findComment-582136 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2013 Author I'm thinking that your cards are hitting their thermal thresholds, so then they're decreasing performance to maintain a safer temperature, hence the sudden frame drops. Do you know roughly what temps your cards are hitting while gaming for an hour or two? Also, how well is your case ventilated? Around 70ish, My ventilation is not the best as my only 2 intakes are infront of my hard drive cadges which are full, I have a 200mm Out take at the top of my case and my rear out take which is going through my H80. If wondering I am using an Antec 902, I am planning on getting a new chassis anyway, I have a 600T in mind. Link to comment https://linustechtips.com/topic/44387-performance-opinions-and-temps/#findComment-582175 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2013 Around 70ish, My ventilation is not the best as my only 2 intakes are infront of my hard drive cadges which are full, I have a 200mm Out take at the top of my case and my rear out take which is going through my H80. If wondering I am using an Antec 902, I am planning on getting a new chassis anyway, I have a 600T in mind. Well I have just looked at the thermal thresehold of the GTX580 and apparently it is around 97c. How many monitors do you run? CPU: Intel Core i5 2550K @ 4GHz | Cooler: Gelid Tranquillo Rev. 2 | Mobo: Gigabyte GA-Z68AP-D3GPU: XFX 1GB HD6850 OC'd | SSD: OCZ Agility 3 60GB | HDD: Samsung 500GB | PSU: Corsair HX520W | Case: Zalman Z11+ Link to comment https://linustechtips.com/topic/44387-performance-opinions-and-temps/#findComment-582270 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2013 Author Well I have just looked at the thermal thresehold of the GTX580 and apparently it is around 97c. How many monitors do you run? I run 3, I only use one while gaming Link to comment https://linustechtips.com/topic/44387-performance-opinions-and-temps/#findComment-582293 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2013 I run 3, I only use one while gaming Hmmmm... I was thinking whether your cards are running out of vRAM. How much memory does your cards have? CPU: Intel Core i5 2550K @ 4GHz | Cooler: Gelid Tranquillo Rev. 2 | Mobo: Gigabyte GA-Z68AP-D3GPU: XFX 1GB HD6850 OC'd | SSD: OCZ Agility 3 60GB | HDD: Samsung 500GB | PSU: Corsair HX520W | Case: Zalman Z11+ Link to comment https://linustechtips.com/topic/44387-performance-opinions-and-temps/#findComment-582313 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2013 Author Hmmmm... I was thinking whether your cards are running out of vRAM. How much memory does your cards have? 1.5GB per card Link to comment https://linustechtips.com/topic/44387-performance-opinions-and-temps/#findComment-582322 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2013 1.5GB per card Okay so you only have 1.5GB of vRAM in total, personally I don't see that becoming an issue, are your monitors 1080p ones? The GTX580 is a good card and with you running them in SLI, I can't see any problems with your cards not being able to keep up. CPU: Intel Core i5 2550K @ 4GHz | Cooler: Gelid Tranquillo Rev. 2 | Mobo: Gigabyte GA-Z68AP-D3GPU: XFX 1GB HD6850 OC'd | SSD: OCZ Agility 3 60GB | HDD: Samsung 500GB | PSU: Corsair HX520W | Case: Zalman Z11+ Link to comment https://linustechtips.com/topic/44387-performance-opinions-and-temps/#findComment-582347 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2013 Author Okay so you only have 1.5GB of vRAM in total, personally I don't see that becoming an issue, are your monitors 1080p ones? The GTX580 is a good card and with you running them in SLI, I can't see any problems with your cards not being able to keep up. yea 1080p monitors, yea im stumped for answers Link to comment https://linustechtips.com/topic/44387-performance-opinions-and-temps/#findComment-582363 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2013 yea 1080p monitors, yea im stumped for answers Same here mate! What settings do you run your games at, max settings? What is your CPU temperature too? CPU: Intel Core i5 2550K @ 4GHz | Cooler: Gelid Tranquillo Rev. 2 | Mobo: Gigabyte GA-Z68AP-D3GPU: XFX 1GB HD6850 OC'd | SSD: OCZ Agility 3 60GB | HDD: Samsung 500GB | PSU: Corsair HX520W | Case: Zalman Z11+ Link to comment https://linustechtips.com/topic/44387-performance-opinions-and-temps/#findComment-582381 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 9, 2013 Author My cpu idles in the 30's and stays in the 30's even when playing games, my h80 is always on mid settings. I never max out games i usually lower the graphics for higher frames as graphics don't bother me. Link to comment https://linustechtips.com/topic/44387-performance-opinions-and-temps/#findComment-582519 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 10, 2013 My cpu idles in the 30's and stays in the 30's even when playing games, my h80 is always on mid settings. I never max out games i usually lower the graphics for higher frames as graphics don't bother me. Hmmmm... I was thinking whether you maxed out your graphics, that at times it peaks the 1.5GB vRAM, hence the frame drops. I'm actually stumped for answers mate. Unless anyone else on here could have any solutions I'm stumped. What about the storage you play games on? Do you run an SSD for games, or a HDD? I'm possibly thinking that the storage can't load the files quick enough. Though I personally don't think this is the problem. The only other reason I can think is that one of your cards are faulty. Is their another GPU you can temporarily try at all? CPU: Intel Core i5 2550K @ 4GHz | Cooler: Gelid Tranquillo Rev. 2 | Mobo: Gigabyte GA-Z68AP-D3GPU: XFX 1GB HD6850 OC'd | SSD: OCZ Agility 3 60GB | HDD: Samsung 500GB | PSU: Corsair HX520W | Case: Zalman Z11+ Link to comment https://linustechtips.com/topic/44387-performance-opinions-and-temps/#findComment-585811 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 10, 2013 Author Hmmmm... I was thinking whether you maxed out your graphics, that at times it peaks the 1.5GB vRAM, hence the frame drops. I'm actually stumped for answers mate. Unless anyone else on here could have any solutions I'm stumped. What about the storage you play games on? Do you run an SSD for games, or a HDD? I'm possibly thinking that the storage can't load the files quick enough. Though I personally don't think this is the problem. The only other reason I can think is that one of your cards are faulty. Is their another GPU you can temporarily try at all? I run my game off an SSD, and my normal hard drives are WD black so even if i was using my hdd there shouldn't be a problem as they are 7200rpm Link to comment https://linustechtips.com/topic/44387-performance-opinions-and-temps/#findComment-586199 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 11, 2013 I run my game off an SSD, and my normal hard drives are WD black so even if i was using my hdd there shouldn't be a problem as they are 7200rpm Okay, the only reason I can think of now is maybe one of them is faulty? Is their another GPU you could try? CPU: Intel Core i5 2550K @ 4GHz | Cooler: Gelid Tranquillo Rev. 2 | Mobo: Gigabyte GA-Z68AP-D3GPU: XFX 1GB HD6850 OC'd | SSD: OCZ Agility 3 60GB | HDD: Samsung 500GB | PSU: Corsair HX520W | Case: Zalman Z11+ Link to comment https://linustechtips.com/topic/44387-performance-opinions-and-temps/#findComment-588564 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
