Ok, so I am planning to purchase the AT2020 and a Phantom Power supply, the power supply has an input where the microphone plugs in and an output, which is, well you guessed it... the output. I was wondering if a XLR to quarter-inch jack cable will work if plugged into the output, I know it won't work if plugged directly into the microphone. BTW, before you say just get the USB AT2020, I need a quarter inch jack output.
https://linustechtips.com/topic/437814-at2020-phantom-power-help/
You shouldn't have any problem if you connect the output from your power supply to the audio jack.
I'm just not 100% sure how much you need to amplify the signal and if that soundcard would destroy the quality anyways.
~ ThxAndBye
"You should remove any cats from the vicinity, because cats will cause all kinds of problems during CPU installation." -Linus
