Cleaning Steelseries mouse pad
Go to solution Solved by Mecami,
If you find that then I'll love you.
Got it!
https://youtu.be/PwEvYuDRMVI?t=221
Sooooooooooooo my cat thought my mug was an evil creature that was attacking my desk and killed my mug..with coffee in it...all over my desk. Thus my mouse pad is now has a lovely coffee scent and stain. Any tips for cleaning it or should I just say screw it and buy a new one? :D
01101100 01110110 01101100 00100000 00110101 00100000 01101101 01100001 01100111 01101001 01101011 01100001 01110010 01110000
https://linustechtips.com/topic/431904-cleaning-steelseries-mouse-pad/
If it's just cloth, get some soap or anything close to it then scrub in water as much as you can without breaking it
If it's a soft cloth one you can even just throw it into the washing machine a few times without a problem.
CPU: i7-4770k (LM modded) - MB: GA-Z87X-UD3H - RAM: HyperX, 16GB 1866MHz - GPU: Palit GTX 980Ti Super - Storage: 1TB HDD + 500GB/120GB SSD (850 Evo/840) - Monitor: Predator XB271HU - PSU: 700W BeQuiet 80+ Gold
 I actually tweeted at steelseries if it was machine washable they said they didn't try and would. I may just because I can get a new one. Only $15 so not that bad.
Linus actually said in one of his older videos that he washed his qck multiple times and that it showed no signs of fraying.
Maybe I can find it...
Got it!
I just use wet wipes for fresh easy stains. Anything other than that I just throw it in the tub and give it a good washing or in the washing machine. Good as new :3
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
