Posted July 28, 2015 I am having troubles with chrome crashing so I am going back to a restore point. About 2 days I saw I restore point made about 8 days ago, but now it is gone? Is there any way to retrieve it. Also I have done everything I can to fix chrome. Desktop 1: CPU: Intel Core i7 4770 GPU: Nvidia Geforce GTX 960 Ram: Crucial DDR3 2x8GB 1600 MHz Storage: Samsung 850 Evo 250GB and Segate 1TB Hard drive Desktop 2: CPU: Intel Pentium G3258 GPU: AMD R7 250 Ram: Corsair Vengance DRR3 2x8GB 1600 MHz Mobo: MSI H81M-E33 PSU: Corsair CX430M Case: Rosewill MicroAtx Mini Tower Link to comment https://linustechtips.com/topic/417368-restore-point-issues/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 28, 2015 Have you tried just re-installing chrome before you go a do a full system restore? Restore points are automatically deleted when the reserved system restore space is filled up. So most likely, if it doesn't show it anymore, it's gone. CPU: i5 4670k • Cooler: Corsair H100i • Motherboard: MSI Z87 MPOWER • RAM: Crucial Ballistix Elite 2x 8GB • Storage: Samsung 840 250GB SSD, 2x WD Red 3TB • GPU: EVGA GTX 780 3GB • PSU: Corsair RM750W • Case: Corsair 750D • Mouse: Razer Naga 2012 (I actually use the thing for productivity/media buttons) • Keyboard: Ducky Shine 3 w/ Browns - Green LED • Monitor: Asus PB278Q 27" 2560 x 1440, ASUS PB238Q 23" 1920x1080 • Lighting: 2m NZXT Sleeved Blue LED Strip • pcpartpicker.com/p/3cHfZ Link to comment https://linustechtips.com/topic/417368-restore-point-issues/#findComment-5612918 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 28, 2015 Author Have you tried just re-installing chrome before you go a do a full system restore? Yes done all sorts of malware/virus scans and reinstalled about 5 times. Desktop 1: CPU: Intel Core i7 4770 GPU: Nvidia Geforce GTX 960 Ram: Crucial DDR3 2x8GB 1600 MHz Storage: Samsung 850 Evo 250GB and Segate 1TB Hard drive Desktop 2: CPU: Intel Pentium G3258 GPU: AMD R7 250 Ram: Corsair Vengance DRR3 2x8GB 1600 MHz Mobo: MSI H81M-E33 PSU: Corsair CX430M Case: Rosewill MicroAtx Mini Tower Link to comment https://linustechtips.com/topic/417368-restore-point-issues/#findComment-5612932 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 28, 2015 Author Help would be much appreciated. Desktop 1: CPU: Intel Core i7 4770 GPU: Nvidia Geforce GTX 960 Ram: Crucial DDR3 2x8GB 1600 MHz Storage: Samsung 850 Evo 250GB and Segate 1TB Hard drive Desktop 2: CPU: Intel Pentium G3258 GPU: AMD R7 250 Ram: Corsair Vengance DRR3 2x8GB 1600 MHz Mobo: MSI H81M-E33 PSU: Corsair CX430M Case: Rosewill MicroAtx Mini Tower Link to comment https://linustechtips.com/topic/417368-restore-point-issues/#findComment-5613117 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 28, 2015 Help would be much appreciated. Sorry, I edited my first post. Basically if you don't see the restore point, then it's probably gone. You could try using something like the CCleaner uninstall option that should also clean the registry. Make sure to reboot between the uninstall and reinstall. Other than that, do you get any kind of crash message or log? Or does it just say "chrome has stopped working"? CPU: i5 4670k • Cooler: Corsair H100i • Motherboard: MSI Z87 MPOWER • RAM: Crucial Ballistix Elite 2x 8GB • Storage: Samsung 840 250GB SSD, 2x WD Red 3TB • GPU: EVGA GTX 780 3GB • PSU: Corsair RM750W • Case: Corsair 750D • Mouse: Razer Naga 2012 (I actually use the thing for productivity/media buttons) • Keyboard: Ducky Shine 3 w/ Browns - Green LED • Monitor: Asus PB278Q 27" 2560 x 1440, ASUS PB238Q 23" 1920x1080 • Lighting: 2m NZXT Sleeved Blue LED Strip • pcpartpicker.com/p/3cHfZ Link to comment https://linustechtips.com/topic/417368-restore-point-issues/#findComment-5613155 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 28, 2015 Author Sorry, I edited my first post. Basically if you don't see the restore point, then it's probably gone. You could try using something like the CCleaner uninstall option that should also clean the registry. Make sure to reboot between the uninstall and reinstall. Other than that, do you get any kind of crash message or log? Or does it just say "chrome has stopped working"? Thanks for the advice. Chrome will get he's dead jim from stuff like going to the settings tab and extensions will randomly crash. Also is revo uninstaller legit to get rid of reg keys when uninstalling programs or does ccleaner does that? Desktop 1: CPU: Intel Core i7 4770 GPU: Nvidia Geforce GTX 960 Ram: Crucial DDR3 2x8GB 1600 MHz Storage: Samsung 850 Evo 250GB and Segate 1TB Hard drive Desktop 2: CPU: Intel Pentium G3258 GPU: AMD R7 250 Ram: Corsair Vengance DRR3 2x8GB 1600 MHz Mobo: MSI H81M-E33 PSU: Corsair CX430M Case: Rosewill MicroAtx Mini Tower Link to comment https://linustechtips.com/topic/417368-restore-point-issues/#findComment-5613204 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 28, 2015 Thanks for the advice. Chrome will get he's dead jim from stuff like going to the settings tab and extensions will randomly crash. Also is revo uninstaller legit to get rid of reg keys when uninstalling programs or does ccleaner does that? They should both do that, but I know off the top of my head that CCleaner definitely tries to clear the registry. Next time you install chrome, try not logging into your Google account. It could be some rogue extension that's automatically getting installed. CPU: i5 4670k • Cooler: Corsair H100i • Motherboard: MSI Z87 MPOWER • RAM: Crucial Ballistix Elite 2x 8GB • Storage: Samsung 840 250GB SSD, 2x WD Red 3TB • GPU: EVGA GTX 780 3GB • PSU: Corsair RM750W • Case: Corsair 750D • Mouse: Razer Naga 2012 (I actually use the thing for productivity/media buttons) • Keyboard: Ducky Shine 3 w/ Browns - Green LED • Monitor: Asus PB278Q 27" 2560 x 1440, ASUS PB238Q 23" 1920x1080 • Lighting: 2m NZXT Sleeved Blue LED Strip • pcpartpicker.com/p/3cHfZ Link to comment https://linustechtips.com/topic/417368-restore-point-issues/#findComment-5613256 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
