installation GPU problems
Go to solution Solved by Adrian Labuschagne,
Thanks for the help my motherboard wasn't compatible with the card maybe because the old one was pcie 2.0 and not 3.0 where the card is pcie 3.0 interface, I replaced it and started up fine only had to repair my windows because it was giving a blue screen when the windows logo started. But everything is back to normal with great improvements.
Hello,
I'm currently stuck and tried a couple of things to fix the problem.
I just bought the Gigabyte R9 290, I inserted it into my system and my fans of my pc, cpu and gpu runs fine but nothing else happens it doesn't even show the bios.
I also tried it in my brothers pc and there it worked fine.
Motherboad: Intel DC61CR
CPU: i5 2400 @ 3.1 GHz
Memory: 8GB HyperX
PSU: Seasonic S12 II 80 Bronze 520W
Help please!
https://linustechtips.com/topic/408797-installation-gpu-problems/
I think that mobo doesn't support it
it is pcie x 16 so it must support it
You should check graphic selector, maybe it is still set to iGPU
CPU AMD FX-6350 @ 4.5Ghz 1.284v Motherboard ASUS M5A97 R2.0 Memory 4x2GB ADATA XPG Gaming v2.0 1600Mhz CPU Cooler Corsair H100i
GPU MSI 270x HAWK Edition Display HP w1907 Storage 1x Samsung 850 EVO 128Gb SSD 1x 400GB Hitachi HDD Case Corsair 450D PSU Corsair CX750M Semi-modular
Keyboard Logitech G105 Blue LED Version Mouse Microsoft Basic Optical Mouse v2.0 Audio 2x Logitech x230 for a Quad-Channel speaker setup OS Windows 8.1
