Power Supplie Cables
Solved by Guest,
Hello guys
I have same this power supplie:
can you tell me for what is :
CPU 1
CPU 2
VGA 1-4
PATA
and I have MSI GTX970 so do I have to connect the cable to the CPU or VGA :lol: ?
Please and thank you
CPU 1 and CPU 2 are for the 4/8 pin cpu connectors. This is usually located at the top left/right of the motherboard.
MB is for the 24 pin motherboard connector near your ram slots.
VGA 1-4 is for the graphics cards
SATA is for Serial ATA drives such as SSD, Hard Drive, Optical drive etc
PATA isn't used anymore (assuming it is Parallel ATA). Those were used on the old type hard drives which used those wide ribbon cables.
You connect the GTX 970 to VGA.
