does anyone have any recommendations for a solar panel phone charger? Or a large battery pack that I can use while camping?
I have £20 to spend but obviously can go higher or lower.
Any suggestions?
CPU: FX-6300 GPU: Sapphire R9 380X MOBO: Gigabyte 970A-DS3P RAM: Corsair Vengeance 8GB PSU: XFX XTR 550W CASE: Zalman Z11 Plus SSD: Samsung 840 Evo
17 years old, PC Enthusiast for 3. Be gentle with me, I'm only young.
https://linustechtips.com/topic/396872-solar-panel-charger/
Any suggestions?
http://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Daps&field-keywords=solar+phone+charger
https://linustechtips.com/topic/396872-solar-panel-charger/#findComment-5351661
https://linustechtips.com/topic/396872-solar-panel-charger/#findComment-5351733
I made one a few years back for a school project, the phone I tested with back then detected it as charging, but the battery percentage drops as you keep it plugged in. Do you want it?  :lol:
Frost | 7700K @ 4.9GHz 1.36v, delidded | Asus DUAL GTX 1060 6GB OC | Corsair LPX 16GB DDR4 2800MHz | Samsung 960 EVO 250GB SSD + Toshiba 1TB HDD + Toshiba 2TB HDD + Samsung 860 EVO 1TB SSD for macOS | Asus PRIME Z270-A | Fractal Design Celsius S24 | Seasonic M12-II 620W PSU | Corsair 400C White | NZXT Hue+
Samsung Galaxy S8 | Stock
Ticwatch E (Black) | Ticwatch Brown Leather Strap
https://linustechtips.com/topic/396872-solar-panel-charger/#findComment-5353186
