Hey there everyone,
I am new to the PC building community and I'm looking for some help with choosing components for my first build. I am on a budget of around $500-600 USD, and would prefer to have a red and black theme with a side windowed case, but can compromise. This build will be used for gaming mostly. Thanks in advance for the help.
https://linustechtips.com/topic/389244-first-pc-build-help-pls/
do you have any peripherals (keyboard, mouse and monitor) and OS?
CPU - i5 4690K @ 4.5Ghz l CPU Cooler - Nepton 240m l GPU - MSI GTX970 gaming 4g 2-way SLI l SLI Bridge - MSI Gaming 2-way L Pro l Mobo - MSI Z97-G45 Gaming l RAM - 2x8GB Vengeance Pro 2133mhz DDR3 l PSU - Corsair HX750i l SSD - 2x Samsung 840 Evo 250GB in raid 0 | HDD - WD Black 2TB | Case - NZXT H440 Red/Black l OS - Windows 10 l Mouse Logitech G502 l MousePad - XTRFY NiP lightning l KeyBoard - Corsair Vengeance K70 RGB (Red) | Headset - Asus ROG Spitfire | Monitor - Asus PG279Q - VG248QE l PCPP - http://pcpartpicker.com/p/sxTpsY | Please don't buy CX PSU for a high end PC
https://linustechtips.com/topic/389244-first-pc-build-help-pls/#findComment-5255111
I have all of the a fore mentioned, but I could use a keyboard upgrade. Also in need of a monitor
for your budget i would keep the keyboard and upgrade it later when you have the money to, and is you mouse wired?
https://linustechtips.com/topic/389244-first-pc-build-help-pls/#findComment-5255135
if you need a monitor... http://pcpartpicker.com/p/zpbGzy
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/389244-first-pc-build-help-pls/#findComment-5255143
if you dont need a monitor http://pcpartpicker.com/p/39WjkL
https://linustechtips.com/topic/389244-first-pc-build-help-pls/#findComment-5255156
I like that list, but I was hoping for a little bit more on the motherboard side. Any suggestions? (I plan to do a slight overclock on the CPU)
would be willing to say 30 to 40 over budget? if yes then sure but otherwise this is the best way to go. if you have a monitor i would stick with it so you could get an i5
https://linustechtips.com/topic/389244-first-pc-build-help-pls/#findComment-5255176
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($42.89 @ OutletPC)
Video Card: Sapphire Radeon R9 280X 3GB Video Card  ($215.98 @ Newegg)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($54.99 @ NCIX US)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($29.99 @ NCIX US)
Monitor: Acer S220HQLAbd 60Hz 21.5" Monitor  ($99.99 @ B&H)
Total: $599.21
Generated by PCPartPicker 2015-06-18 19:16 EDT-0400
https://linustechtips.com/topic/389244-first-pc-build-help-pls/#findComment-5255185
A 280x would be better then a 960
https://linustechtips.com/topic/389244-first-pc-build-help-pls/#findComment-5255197
i second this
https://linustechtips.com/topic/389244-first-pc-build-help-pls/#findComment-5255199
I would say $650 is my absolute max for my budget
http://pcpartpicker.com/p/WyXdTWyou can get this, and when you get the rebate money back you can purchase a hyper 212 evo
https://linustechtips.com/topic/389244-first-pc-build-help-pls/#findComment-5255233
it costs more, i am not counting rebates anyway as the final price.
https://linustechtips.com/topic/389244-first-pc-build-help-pls/#findComment-5255245
the 10$ difference is worth it
https://linustechtips.com/topic/389244-first-pc-build-help-pls/#findComment-5255273
m8 its a 30 dollar difference
https://linustechtips.com/topic/389244-first-pc-build-help-pls/#findComment-5255289
Thanks for your help guys! I'll be sure to post pictures and everything once it's built. It wont be for a while, but I figured I'd start researching.
may you please tell me what you will be purchasing? just want to make sure
https://linustechtips.com/topic/389244-first-pc-build-help-pls/#findComment-5255335
215$ vs 205$ well... 215$ vs. 195$ if you count in mail rebates... so NOT 30$ difference...
https://linustechtips.com/topic/389244-first-pc-build-help-pls/#findComment-5255356
listen to me m8 the 280x you are talking about costs 232
http://pcpartpicker.com/part/sapphire-video-card-100363vx3l
then is 215 after mail in rebate. mail in rebates take months to be processed
https://linustechtips.com/topic/389244-first-pc-build-help-pls/#findComment-5255370
hmmm. i didn't realise 315$ was after inmail rebate, sorry :P
https://linustechtips.com/topic/389244-first-pc-build-help-pls/#findComment-5255384
its k, happens
i also admit its better but not by much. the 960 its more power efficient, quieter and outputs less heat
https://linustechtips.com/topic/389244-first-pc-build-help-pls/#findComment-5255386
