NZXT H440 airflow
Solved by Fredrikmikael,
simple. #1 for air cooling. #2 for watercooling.
The front fans are hindered by the filter, thus it wont create positive pressure, if you have three intakes and three exhausts. I was debating over this in my thread for my H440 and got recommended this - Leave the front as intakes, top as exhaust and flip the rear to intake as well (just put a filter there) - THAT will be positive pressure
Allright, changed the rear fan to intake.
Thanks for the help ![]()
