Please dear god help me! I have tried disabling the in game settings and still setting CCC to ignore the game settings but they NEVER seem to F****** apply! So frustrating.....
  • CPU: AMD Ryzen 2700X
  • Motherboard: MSI X470 Gaming Pro
  • RAM: 32 GB HyperX Fury DDR4 2400
  • GPU: MSI 5700XT MECH
  • Case: Fractal Define R5
  • Storage: 1TB WD Black 7200 RPM HDD, 2TB WD Black 7200 RPM HDD, 4TB WD Black 7200 RPM HDD, Samsung Evo 960 1TB SSD
  • PSU: Corsair CX750M
  • Display(s): HP 24W
  • Cooling: 1 120mm Corsair fan, Noctua NH-U14S
  • Keyboard: Razer Blackwidow 2016
  • Mouse: Razer Deathadder Basilisk.
  • Sound: Razer 7.1 Kraken Chroma V2, LG SJ4Y 300W soundbar
  • Operating System: Windows 10 Professional 64 bit
What game and what settings are you trying?
Just any game NONE of them work .-.
Also any setting... I can't get any of them to work D:
So after disabling the ingame settings, you made a profile for whatever game you were attempting this on and then flicked the "use application settings" off, right? Make sure you make a profile or it usually won't work.
Yes... I it is so annoying especially when I hear of fixes using CCC or Nvdia control panel
I is tired. Be back on tomorrow
Alright please help :D
