"Project Bad Wolf" parts list
PCPartPicker part list: http://ca.pcpartpicker.com/p/cNQpLk
Price breakdown by merchant: http://ca.pcpartpicker.com/p/cNQpLk/by_merchant/
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor ($79.98 @ DirectCanada)
CPU Cooler: Cooler Master Hyper T4 70.0 CFM Rifle Bearing CPU Cooler ($25.64 @ DirectCanada)
Motherboard: MSI H97 PC MATE ATX LGA1150 Motherboard ($110.75 @ Vuugo)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($69.99 @ NCIX)
Storage: Seagate 1TB 3.5" 7200RPM Hybrid Internal Hard Drive ($79.99 @ NCIX)
Video Card: Asus GeForce GTX 960 2GB Video Card ($254.99 @ NCIX)
Case: Deepcool TESSERACT SW ATX Mid Tower Case ($44.98 @ Newegg Canada)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply ($44.97 @ DirectCanada)
Case Fan: Cooler Master R4-L2R-20AC-GP 69.0 CFM 120mm Fan ($6.40 @ DirectCanada)
Case Fan: Cooler Master R4-C2R-20AC-GP 69.0 CFM 120mm Fan ($6.69 @ DirectCanada)
Total: $737.18
Generated by PCPartPicker 2015-06-07 05:05 EDT-0400
As you can see am planing on using Cooler Master R4's fans because they have high air flow, are quiet, and have 50,000 hour life spans and I'm getting a lot of them, Because I will be OC'ing and want good cooling and yes I know the case I picked comes with fans, however multiple reviewers on Newegg have said the fans that come with my case I have chosen are pretty crappy and don't last long. However 2 thing I dont is is if the R4's will fit the hyper T4 CPU Cooler because the 32 decibels on the stock fan doesn't appeal to me and want to replace it with an R4 and have a push-pull configuration. And if the cable is long enough on the R4 to use it as an intake fan with the mobo and case I have picked.
I've already started this build by purchasing SSHD when it was on sale at Memory Express and using my $50 gift card I can't wait to get the rest of it and start building! And then gaming and recording!
Systems built (personal) | 1. Bad Wolf (Has passed on to PC Heaven): https://ca.pcpartpicker.com/b/zX9WGX |  2. Red Husky: https://ca.pcpartpicker.com/b/Mwhypg
Systems built (for commission) | 1. Red Fox: http://ca.pcpartpicker.com/b/W4LD4D | 2. Not Namedhttp://ca.pcpartpicker.com/b/TMhqqs 3. Bad Wolf 2.0: https://ca.pcpartpicker.com/b/7p8Ycf upgraded Bad Wolf to an I3-7100 for my friend as a gift|
https://linustechtips.com/topic/381984-need-advice-with-cooling/
For overclocking a dual core Pentium, 2 case fans and a nice aftermarket air CPU cooler should be absolutely fine.
I'd personally get an i3 on that budget
Didn't see you were from the mapleland of Canadia
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
https://linustechtips.com/topic/381984-need-advice-with-cooling/#findComment-5158505
Ya.. Getting gaming PC parts in Canada right now is a bitch, damn low oil prices and I'm in the oil province as well xD.
However still didn't answer my question.
https://linustechtips.com/topic/381984-need-advice-with-cooling/#findComment-5158542
Woops
https://linustechtips.com/topic/381984-need-advice-with-cooling/#findComment-5158548
