So I made a build which someone recommended for me from here, however at the time I had no intentions of playing Counter-Strike.
I've decided to started to play, and I'm experiencing A LOT of lag/skipping within matches.
Here's my specs.
http://gyazo.com/cab7c1fa73cddbba7b6d974d9cc9ce1d
I think my GFX is built into my processor or something? (I have no clue,
So according to 'systemrequirementslab' - I need something which has this:
"Video card must be 256 MB or more and should be a DirectX 9-compatible with support for Pixel Shader 3.0"
Within a £50 GBP price range, and must be compatible with my other parts.
https://linustechtips.com/topic/356694-csgo-help-gfx-card/
Here's my specs.
CS:GO uses more cpu and gpu. For this budget you would probably could get a gt 730 but i would say that save your money and get a r7 260x
https://linustechtips.com/topic/356694-csgo-help-gfx-card/#findComment-4841331
Here's my specs.
Looks like you are using the onboard graphics but there isn't much that outperforms the IGPU at this price range maybe a gt 730.
https://linustechtips.com/topic/356694-csgo-help-gfx-card/#findComment-4841337
I can't see that image so I can't help you. But in general an intel CPU and any GPU will be able to push 300fps in this game.
My pentium G3258 and a gtx 650ti pushes around 160fps whaa
https://linustechtips.com/topic/356694-csgo-help-gfx-card/#findComment-4841361
Do I need to buy a specific type? On Amazon I can see NVidia and Asus
The card is nvidias but there are different models try getting the Asus or for 4£ more the gigabyte one
https://linustechtips.com/topic/356694-csgo-help-gfx-card/#findComment-4841403
https://linustechtips.com/topic/356694-csgo-help-gfx-card/#findComment-4841448
https://linustechtips.com/topic/356694-csgo-help-gfx-card/#findComment-4841460
Yeah, I don't know how to do that either  :huh:  -_-
Do you have a built pc or a pre-build one?
https://linustechtips.com/topic/356694-csgo-help-gfx-card/#findComment-4841489
can you open the side panel and take a picture?
https://linustechtips.com/topic/356694-csgo-help-gfx-card/#findComment-4841501
Do you have the receipt for the parts?
https://linustechtips.com/topic/356694-csgo-help-gfx-card/#findComment-4841515
https://linustechtips.com/topic/356694-csgo-help-gfx-card/#findComment-4841543
