SATA/Power to usb cable
Go to solution Solved by MrBucket101,
@Matty175rocks
http://www.amazon.com/AGT-External-Power-Supply-Adapter/dp/B00B42UTFO
Then just buy a MOLEX -> SATA power adaptor
http://www.amazon.com/USB-SATA-5-25-Cable-Adapter/dp/B000YJBL78
no point in getting usb 3.0, you're not doing anything that would benefit from it.
Hey I have a old dvd drive that I want to connect to my laptop, so I need a Usb adaptor to SATA and power. But I need the power to run off the wall like a 12v AC adaptor. If you find an adaptor could you please put the link in the chat. Btw I would prefer it to be USB 3
Thanks
https://linustechtips.com/topic/355696-satapower-to-usb-cable/
@Matty175rocks
https://linustechtips.com/topic/355696-satapower-to-usb-cable/#findComment-4829046
