Can your soundcard or whatever you use output to analog and digital at the same time?  If so, then, assuming your soundbar accepts a digital input, you could hook up your sound bar via the digital out and plug your headphones into the analog out.  Otherwise, some kind of splitter would be the simplest.
Thrive on change. Embrace volatility.
https://linustechtips.com/topic/351114-using-speakers-for-bass/#findComment-4775526
