I'm a noob needing help !
Go to solution Solved by AliveGhost13,
Is it this thing? - http://www.amazon.co.uk/HEC-Compucase-G7-Modular-Extreme/dp/B008O0VT08
Also, what temperatures does your CPU get up to?
Hi, I have created this topic as I am in need of help and don't want to screw up, I want to upgrade my graphics card because on GTA V it get a maximum of 25FPS on the settings I would prefer. I think it's my graphics card what needs upgrading, as I said in the title I'm a complete novice. Here are my specs on my current build
Cooler Master CM690 II case
950W High Efficiency G7 Extreme Modular Super Silent Power Supply
MSI B75MA-E33 Intel Motherboard
i7-3770 Quad Core Processor 3.5Ghz
3GB AMD RADEON HD7950
2TB SATA III 6Gb/s, 7200rpm, 64MB Cache, 8ms Hard Drive
As I said I don't know what to do to help my FPS , I've tried using AMD overdrive and yet still had no avail, if any parts are in need of upgrading my price range is about £300-£400, any help and tips would be greatly appreciated.
https://linustechtips.com/topic/350323-im-a-noob-needing-help/
Well the only option is upgrade PSU (that one sounds horrific) and upgrade GPU, the CPU is still very strong
What temps do you get when running it?
i5 4670k - Z87X-UD3H - EVGA GTX 670 Sig 2 - Samsung 840 Evo 250GB - 8GB Avexir Core White 1600Mhz - Corsair 750D w/ RGB LED Mod & Remote Control - 2x SP120 - 3x Enermax Cluster - 2TB Seagate SSHD - Arctic Freezer 7 Pro Rev.2 - SuperFlower Leadex Gold 750W
https://linustechtips.com/topic/350323-im-a-noob-needing-help/#findComment-4765924
Crap, got the wrong wattage on the PSU ahah sorry, it's actually 950W, and so I only need to upgrade my GPU, could you perhaps give me a suggestion for my price range ? And by temps I assume you mean temperature, and when playing GTA for around 30 minutes the temperature of my GPU is around 50-60 degrees Celsius.
https://linustechtips.com/topic/350323-im-a-noob-needing-help/#findComment-4766024
https://linustechtips.com/topic/350323-im-a-noob-needing-help/#findComment-4766028
Update: I've been searching around and a GPU what seems to be around my price range is the AMD radeon R9 290X, would this work with my build, or could I get a GPU what suits my build better, and improve performance even if slightly more expensive ?
https://linustechtips.com/topic/350323-im-a-noob-needing-help/#findComment-4767114
