I have a Palit GTX970 blower style card and pretty soon after getting it I took the fan off because the noise was horrible, I knew it would be louder than my 7850 since it was a blower but I was not expecting it to be that loud. Anyway, I was wondering if there's any replacement heatsink/fans I can install on it? I was looking at the arctic GPU fans but since my case is an elite 130, I dont I have enough clearance on the side to fit any of them in. The front 120 has a rad that i used for my CPU so I cant install a GPU AIO. I've spent most of the time since i've had it with a 120mm fan ghetto-mounted to the heatsink - the temps are pretty good even with my overclock it's just a matter where I'd like to actually close my case for once.
Any ideas?
https://linustechtips.com/topic/336588-gtx-970-replacement-fan/
