Help with VB Project - Can't fix error
By
aom
in Programming
in Programming
Solved by aom,
I found my problem, while I turn off the visibility of the panel, the controls inside of it were still enabled and overrided my keypress controls. So all i had to do was also disable the panel too. Thanks for your help though.
Vibora ·
Posted in New Builds and Planning3 -
4
3
Doctah ·
Posted in Peripherals1 -
5
michaelb198 ·
errorcode123_dindin1 ·
Posted in Graphics Cards3 -
Packhunter ·
Posted in Graphics Cards5
