Get an i5 4690k and a GTX 770 or a 960. (if these fit in your budget)
Desktop: i5 4670k, Z97-K, 16GB, MSI GTX 770, Evga 850G2, TT T31
Freenas Server: i3 4170, X10-SLL-F-O, Crucial 16GB UDIMM, 4x4TB WD Red, Evga 550GS, Fractal 804
Peripheral: K60, HyperX Cloud
Mobile: Nexus 6P
https://linustechtips.com/topic/320181-my-first-pc-build/#findComment-4351552
I see all sorta bad choices.
Ryzen 3700x -Evga RTX 2080 Super- Msi x570 Gaming Edge - G.Skill Ripjaws 3600Mhz RAM - EVGA SuperNova G3 750W -500gb 970 Evo - 250Gb Samsung 850 Evo - 250Gb Samsung 840 Evo  - 4Tb WD Blue- NZXT h500 - ROG Swift PG348Q
https://linustechtips.com/topic/320181-my-first-pc-build/#findComment-4351559
Is my pc build good or should i try something new
I have to keep it under 1000
http://pcpartpicker.com/p/wQYW7P
This is more along the lines of something I think would be good for you. Not only does it have better cpu and much better gpu it's also got headroom for more stuff in the budget.
https://linustechtips.com/topic/320181-my-first-pc-build/#findComment-4351597
I would go 290 over 960 any day
Yeah it would definitely be more powerful in all scenarios. The OP needs to make sure he does a lot more research before this build, not to offend him but that setup is very misguided. @Jax827 keep revising and think it over and scour the internets for at least a week or two, get to know all the hardware available first.
https://linustechtips.com/topic/320181-my-first-pc-build/#findComment-4351626
