OK, just because you have no output does not mean it is your video card. Do you get any beeps when you turn on the machine?
“When life gives you lemons, don’t make lemonade. Make life take the lemons back! Get mad! I don’t want your damn lemons, what the hell am I supposed to do with these? Demand to see life’s manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I’m the man who’s gonna burn your house down! With the lemons! I’m gonna get my engineers to invent a combustible lemon that burns your house down!”
- Cave Johnson, founder and CEO of Aperture Science, in Portal 2
https://linustechtips.com/topic/311543-no-input-signal/#findComment-4234492
I know this may seem like a stupid question, but are all the parts in the computer?
https://linustechtips.com/topic/311543-no-input-signal/#findComment-4234580
Also, does your motherboard have onboard graphics?
https://linustechtips.com/topic/311543-no-input-signal/#findComment-4234594
Then yes. Take the video card out, and plug your monitor into the connector on the back of the computer. If it works return your graphics card to the manufacturer for a new one. If it doesn't then you have to dig a little deeper
https://linustechtips.com/topic/311543-no-input-signal/#findComment-4234619
Have you tried taking the graphics card out yet and using the onboard VGA connector that is on the motherboard? Also, are you on the correct connector?
https://linustechtips.com/topic/311543-no-input-signal/#findComment-4234633
Then yes. Take the video card out, and plug your monitor into the connector on the back of the computer. If it works return your graphics card to the manufacturer for a new one. If it doesn't then you have to dig a little deeep
our montherboard doesnt have inputs or outputs
https://linustechtips.com/topic/311543-no-input-signal/#findComment-4234639
What? What is the name of your motherboard?
https://linustechtips.com/topic/311543-no-input-signal/#findComment-4234647
No, FX-8350 doesn't have integrated graphics, neither does the rest of the platform.
https://linustechtips.com/topic/311543-no-input-signal/#findComment-4234651
Oh whoops! I read that wrong. You are correct
https://linustechtips.com/topic/311543-no-input-signal/#findComment-4234670
What happens when you turn it on?
https://linustechtips.com/topic/311543-no-input-signal/#findComment-4234711
