Hey guys so I want to try and get my temps down and my noise levels down. I know a bit about water cooling and want to try it.
I'm not sure what my budget should be so Low-Medium
Im okay with radiators outside of the case as well.
Any suggestions?
--PC Specs--
CPU: Intel Core i7-4770K Haswell Quad-Core 3.5GHz
GPU: ASUS Radeon R9 290 4GB
RAM: 8GB (2 x 4GB) DDR3 1866
Motherboard: Gigabyte Z97X-Gaming 3
PSU: 650Watt 80 plus bronze
HDD: 1TB Seagate 2TB Seagate.
SSD: 128GB Adata
Case: Corsair Carbide 300R
Fans: 2 140MM Corsair AF (Red LED) 3 120MM Corsair AF (Red LED) 2 Corsair SP 120MM.
https://linustechtips.com/topic/308724-help-with-water-cooling/
NZXT Kraken X61
9590|EK-Copper|Sabertooth 990FXR2.0|16GB RIPJAWS Z|Dual MSI Gaming 290|Corsiar AX1200i|Corsair 760T|3TB Seagate+Dual 120GB Samsung 850EVO in Raid 0
LTT'S Official Radeon Master Race Club Founder-Predicts TitanX2 (Prediction Date: 3-30-15)
XFX Needs To Make A 3 Fan Cooler
https://linustechtips.com/topic/308724-help-with-water-cooling/#findComment-4195961
@MLGNOSCOPEHEADSHOTGETREKT @TokyoSin I'm interpreting the "Im okay with radiators outside of the case as well." as he wants a custom loop
EK are my personal favourite (@JayzTwoCents also likes them) for blocks, and they have quite a range, even if they are a bit pricey :/  They have a website that allows you to find compatible blocks for your hardware here: http://coolingconfigurator.com/
There are a few other companies such as swiftech, XSPC, and Aqua Computer to name a few
Specs: CPU: AMD FX 6300 Motherboard: Gigabyte 970A DS3P RAM: HyperX Fury 16GB 1866MHz GPU: MSI R9 270 OC edition Case: Sharkoon VS3-S SSD: Samsung 840 EVO 120GB HDD: 1TB Caviar Blue PSU: Corsair CX500W
*If I say something that seems offensive, please don't take it seriously, it was most likely meant as a joke/sarcastically*
https://linustechtips.com/topic/308724-help-with-water-cooling/#findComment-4196036
Thanks! I will take a look! :D Any other advice?
https://linustechtips.com/topic/308724-help-with-water-cooling/#findComment-4196104
With the actual build?
Just take your time and read the manuals for everything, and don't be afraid to look things up/ask someone if you're not sure. After all, you could potentially kill a $300 GPU if you do manage to royally mess up. However, in EK waterblocks the threads stop, meaning you'd strip the block before you destroy the card.
*I just thought I'd add that I've never actually watercooled before, and all knowledge has been acquired from videos such as SingularityComputers or JayzTwoCents*
https://linustechtips.com/topic/308724-help-with-water-cooling/#findComment-4196146
tbh, you'd be way better off using a proper chassis than making the 300R into
something it is not a water cooling case. will make the experience easier, less
foul-language because it doesn't work and what you are doing costs money
and hate to see that case ruin your needs/wants for water cooling.
https://linustechtips.com/topic/308724-help-with-water-cooling/#findComment-4198220
What case would you recommend? :)
https://linustechtips.com/topic/308724-help-with-water-cooling/#findComment-4227010
  • 2 weeks later...
