Amazon id>1423615166
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.XFan+Extension+4pin&_nkw=Fan+Extension+4pin&_sacat=0
Next time spend 4 seconds searching, not 2.
I can see plenty of cheap splitters and extensions and they're $3 at most.
https://linustechtips.com/topic/308233-fan-extension-cables/#findComment-4188984
Just be nice.
https://linustechtips.com/topic/308233-fan-extension-cables/#findComment-4189009
How am I supposed to tell you're joking. This is the internet.
Why did the chicken cross the road?
I wish posting LMGTFY links was allowed so I could teach you what sarcasm is and why you can't tell if someone is being sarcastic on the internet.
Let me break down why its a joke:
 - Implies that you can find out facts in 4 seconds
not 2
 - Implies SEARCH HARDER because you haven't been looking hard enough. If the only stuff you found was $5, then you've got your answer and you're wasting our time. Looking around a few local sites and ebay I found 2x fan extensions under $5 several times.
https://linustechtips.com/topic/308233-fan-extension-cables/#findComment-4189045
