1. Budget & Location
Budget: Around 1200, i still have a couple things from my current PC that i would be using.
2. Aim
This will be for mostly gaming, although i did want to know my options for streaming games on twitch also. I play everything, League of Legends, Skyrim, Rust, CSGO, Civ5, everything.
3. Monitors
Currently 2 monitors, plan on getting a 3rd. But gaming would only be on 1 monitor. 1080p gaming, 4k if that is an option, if it isn't for this budget how much more would i need to spend?
4. Peripherals
Ive got Windows 8.1(soon to be windows 10), mouse, keyboard, and everything else that i need.
5. Why are you upgrading?
I am upgrading from
i3 520
eVGA P55v
GTX 460
8GB Ram
And here is what i would be using again
Brand New Corsair CX750M
Corsair Carbide 300R
250GB SSD
Few TBs of storage
https://linustechtips.com/topic/307313-need-help-with-new-build/
I just meant that windows was covered.
Here is what i have
http://pcpartpicker.com/p/Pp6pMp
Here is 1 of the builds i was thinking. I kept the memory i have.
http://pcpartpicker.com/p/f9VmJx
This is the other build that is more expensive but if i am going to see a big difference in performance i will get it.
http://pcpartpicker.com/p/G6C423
https://linustechtips.com/topic/307313-need-help-with-new-build/#findComment-4175612
Don't combine a water cooler with a locked cpu. Either get an unlocked cpu or use the stock cooler or something like a 212 evo
G3258 @ 4.5 | 8GB Team Vulcan RAM | 128GB Kingston V300 SSD (I didn't know what I was doing when I bought it) | MSI H81I Motherboard | Corsair H55 with Noctua NF-P12 | EVGA SSC GTX 960 4GB | OCZ 550W Fully Modular PSU with Noctua NF-A14 | Cooler Master Elite 130 (Soon to be something cool)
https://linustechtips.com/topic/307313-need-help-with-new-build/#findComment-4175680
Very similar to first build. But an unlocked processor to allow for overclocking - the cpu is only a few dollars more. A different motherboard, one that supports SLI. The reasoning is that a single GTX 970 will meet current needs and a second one can be added to handle higher resolutions.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($214.95 @ SuperBiiz)
CPU Cooler: Corsair H80i 77.0 CFM Liquid CPU Cooler  ($79.99 @ Amazon)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($132.99 @ SuperBiiz)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  (Purchased For $0.00)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive  (Purchased For $0.00)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card  ($326.99 @ SuperBiiz)
Case: Corsair 300R ATX Mid Tower Case  (Purchased For $0.00)
Power Supply: Corsair CX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($79.99 @ Amazon)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  (Purchased For $0.00)
Total: $834.91
Generated by PCPartPicker 2015-02-09 10:14 EST-0500
https://linustechtips.com/topic/307313-need-help-with-new-build/#findComment-4175706
PCPartPicker part list: http://pcpartpicker.com/p/wzJg4D
Price breakdown by merchant: http://pcpartpicker.com/p/wzJg4D/by_merchant/
CPU: Intel Xeon E3-1230 V2 3.3GHz Quad-Core Processor  ($228.99 @ Directron)
Motherboard: ASRock B75 Pro3 ATX LGA1155 Motherboard  ($70.89 @ SuperBiiz)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory  ($64.99 @ Amazon)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive  ($131.88 @ OutletPC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($43.79 @ OutletPC)
Video Card: Gigabyte Radeon R7 260X 2GB WINDFORCE Video Card (2-Way CrossFire)  ($109.99 @ Newegg)
Case: Corsair 300R ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: Corsair CX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($74.99 @ Micro Center)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($89.98 @ OutletPC)
Total: $975.48
Generated by PCPartPicker 2015-02-09 10:26 EST-0500
This any good?
https://linustechtips.com/topic/307313-need-help-with-new-build/#findComment-4175785
Total: $975.48
This any good?
It's alright but for gaming the zeon dosen't excel and 1 decent graphics card tends to perform better than 2 really crappy low end ones
https://linustechtips.com/topic/307313-need-help-with-new-build/#findComment-4175819
No real reason why i preferNvidia anymore i know that AMD has stepped up lately, i probably would get a AMD if it is going to make a difference.
As for the Cooler, i actually did mean to pick a unlocked ill fix that.
Looking the builds posted, is it not worth it to get 6 core right now? And 2 R7 260X would be better then 1 GTX 970? Even factoring in later buying another one. I know you can't future proof, but i know that when the graphics card starts to become dated adding a 2nd GTX 970 which will have dropped in price by then i assume would help out. Remember my budget is 1200 and i could probably go to like 1600 if it is going to be worth it.
Edit: Also, i already have the storage drives Case and PSU, so this is more of a upgrade instead of a new build.
https://linustechtips.com/topic/307313-need-help-with-new-build/#findComment-4175834
PCPartPicker part list: http://pcpartpicker.com/p/rMjBWZ
Price breakdown by merchant: http://pcpartpicker.com/p/rMjBWZ/by_merchant/
Motherboard: ASRock Z77 Extreme3 ATX LGA1155 Motherboard  ($97.99 @ Newegg)
Storage: Western Digital Caviar Blue 500GB 3.5" 7200RPM Internal Hard Drive  ($38.99 @ Amazon)
Total: $1104.79
Generated by PCPartPicker 2015-02-09 10:43 EST-0500
Fine, this any better?
https://linustechtips.com/topic/307313-need-help-with-new-build/#findComment-4175894
PCPartPicker part list: http://pcpartpicker.com/p/4VjBWZ
Price breakdown by merchant: http://pcpartpicker.com/p/4VjBWZ/by_merchant/
Video Card: Sapphire Radeon R9 270X 4GB Dual-X Video Card (2-Way CrossFire)  ($172.99 @ SuperBiiz)
Total: $1096.68
Generated by PCPartPicker 2015-02-09 10:49 EST-0500
And here, an Amd crossfire with "noncrappy" cards.
https://linustechtips.com/topic/307313-need-help-with-new-build/#findComment-4175933
I don't need the 500gb drive, and i'm not sure about the Xeon, i don't know much about them, but i know that everyone is buying i5 or i7 for gaming rigs, i think those are more for like workstations?
I updated the list i made
Here is what i have
https://linustechtips.com/topic/307313-need-help-with-new-build/#findComment-4175937
Here is what i have
You need to update the links in your post with new permalinks - they change when a configuration changes.
Xeon are intended for workstations and servers. However, they share the same basic Haswell architecture and in some builds are a better choice because of their picing. They are no more nor less suitable for gaming than i5 and i7. They have the advantage of hyperthreading at a cost somewhere between i5 and i7.
https://linustechtips.com/topic/307313-need-help-with-new-build/#findComment-4175982
Total: $1096.68
This build is completely irrelevant and I would suggest ignoring most of the comments made from this user.
Also this person doesn't seem to listen to understand that your budget is $1200 on top of the parts you already have.
I will put together a build suitable for your needs and budget shortly here... but seriously do not listen to this guy.
https://linustechtips.com/topic/307313-need-help-with-new-build/#findComment-4176062
He's trying to help i appreciate that, but yea i don't know if he understood about how my budget is working.
https://linustechtips.com/topic/307313-need-help-with-new-build/#findComment-4176109
