So all of a sudden to day my sound on my motherboard is bugging out were it's really quite and sounds very bad through front panel and rear
Update the back audio works now but when i switch to front audio they try to play through both making such a bad sound
l Intel Core i7 4790K @ 4.5Ghz l Asus VII Ranger ROG l MSI GTX 970 @ 1555MHz l
PC PART PICKER
https://linustechtips.com/topic/303806-motherboard-issue/
Something your front panel audio cable is running past is probably interfering. I would suggest get a new shielded front panel audio cable.
This is quite common. I don't use front panel audio for the same reason.
One Steam to rule them all, One Sale to find them, One Sale to bring them all and with their wallets, bind them! - r/pcmasterrace 17/01/2014
  • CPU: Intel Core i7 6700k
  • CPU Cooler: CM Hyper 212+
  • RAM: 16GB Kingston HyperX Fury 2400Mhz (2x8GB)
  • GPU: Gigabyte G1 R9 390
  • Mobo: Asus Z170-AR
  • PSU: Antec High Current Gamer 900W
  • Storage: 240GB intel 520 SSD (OS), Sandisk 128GB SSD(Other OS) 2x 2TB Seagate Barracuda
  • Case: Fractal Design R4
https://linustechtips.com/topic/303806-motherboard-issue/#findComment-4129515
no i found the issue the mobo audio is dead because it was working fine for the last month and i pluged it into a different port and its fine just the front audio does not work like its really bad and its not interferance because its been that way for the last month just fine but thanks for the suggestion
PC PART PICKER
https://linustechtips.com/topic/303806-motherboard-issue/#findComment-4129602
The front and rear audio come off the same thing (unless you have a dedicated soundcard) so if it were dead you would have no (or broken) sound on rear audio as well.
does you board still have the AC'97 header or just HD audio?
https://linustechtips.com/topic/303806-motherboard-issue/#findComment-4129705
its just HD audio and it seems to be just the 2 ports as when i turn the computer off there is a loud pop that goes through the speakers and when i plug it in to the other port its fine so it seems like front audio is broken because the only audio you get from it is a strange mixture of highs and lows and the back one is just very quiet and distorted. going to contact overclockers in the morning to send me a new one
PC PART PICKER
https://linustechtips.com/topic/303806-motherboard-issue/#findComment-4129742
