Power supply compatibility problems
Go to solution Solved by Guest,
Yup
You can use PWM fan splitter cables then.
http://www.amazon.co.uk/Akasa-AK-CBFA04-15-Splitter-Cable-Fans/dp/B005FWXWPS/ref=pd_sxp_grid_i_0_0
Or this if you want to run up to 5 fans from a single header - http://www.amazon.co.uk/Akasa-AK-CBFA03-45-Flexa-Splitter-Cable/dp/B005EKU5CO/ref=pd_sxp_grid_pt_1_1
Most good pc shops will sell similar cables.
Case fans don't use a lot of power. How many are you trying to connect ? And are they 3 pin or 4 pin ?
You can use splitter cables to run multiple fans off one header.
I'm trying to run at least 3 Noctua NF-F12s and I heard somewhere that the max supported fans was 3? But I'm not sure if I might want more because I'm running a Noctua NH-D15 in a Corsair C70 case and I was thinking with the dual fan heatstack I'd get better cooling if I also have one fan intaking from the top front intake to provide some cool air for the first heatsink fan sitting over the ram?
Are they these fans ?
http://www.overclockers.co.uk/showproduct.php?prodid=FG-009-NC&groupid=701&catid=2331&subcat=4
Yup
Thanks a lot and do you know if you can change the fan speed on those without a fan controller?
You don't need a fan controller for 4 pin PWM fans as the motherboard can automatically control the speed. So if your pc is running idle (Internet browsing etc) then the fans will run slow. If you start to work the pc (Gaming etc) then the speed will adjust to suit.
Thanks
