Hello Everyone!
So i recently bought another ssd to run along in my system.
This is my second ssd so ive installed one of these successfully already
My story is that when i installed it and turned my system on
then accessed the bios it clearly showed it plugged in.
However due to an accidental hit of the power button my system
shut down while i was in the bios.
I wasnt doing anything critical or changing any settings so
I dont believe this matters however
when i went  to turn my system back on it no longer was able to
detect the new SSD. My old one and my hard drive read fine.
I have tried switching the SATA cords and power input also tried
different ports on the motherboard.
 So somewhere in the vast universe of google someone had a
similar case to mine and mentioned that
by removing their motherboards cmos battery and then
replacing it 10 minutes or so later it allowed the
motherboard to recognize the new SSD.
My question is how can i get my motherboard to read this SSD?
If  I do try to remove the cmos battery what does that effect?
Any help is appreciated!
https://linustechtips.com/topic/292413-ssd-issues-cmos-removal/
  • Intel i5 2500k
  • Motherboard
    Gigabyte z77x up4th
RAM
1x8gb A-Data DDR3 1600 ram
GPU
Evga & Gigabyte Geforce GTX 760 2gb SLI
Case
Thermaltake Versa II
Storage
240 GB Intel 530 SSD & WD 1 TB Blue
PSU
Rosewill Photon 750 watt
Display(s)
Asus VX228 & Dell U2412B
Keyboard
Rosewill RGB80 & Razer Tartarus RZ07-0103
Mouse
Logitech G600
Sound
On Board
Operating System
Windows 8 Pro
https://linustechtips.com/topic/292413-ssd-issues-cmos-removal/#findComment-3971459
