So I need a fan controller for my new build, just so the OEM fans in the case and the one Spectre I had for it don't get noisy when they don't need to be, I just want to undervolt them to the point where they aren't all super annoying to hear, but still give me good preformance. Of course I'll turn them on full tilt when I need to.
My question is with this Fan controller here: http://www.xoxide.com/phobya-4-control-fan-controller.html
Can I use 2 splitters and run 4 fans to 2 header without undervolting the fans by a lot? That way I can crank them up when BF4 comes out ;) Then I'll just connect 2 more fans to the last 2 headers. But I'd really like to control my 2 front intake fans together and my 2 bottom intake fans together as well.  Then the one blowing inside and the rear exhaust seperately.
Thanks for the help, IF that one doesn't work, any > 30 dollar CAD reccomendations for fan controllers with 4 headers I can use? In black. (All my fans are 3 pin, non are PWM)
Case: NZXT H440 | CPU: i5 4670K @ 4.5 GHz | GPU: MSI 970, Kraken G10 | Mobo: ASRock Z97 Extreme3 | Cooler: H100i | PSU: Corsair AX750 w/ Sleeved Cables | Display: 3xBenQ RL2455M | Fans: 5xNoctua NF-F12, 1xBitFenix Spectre |
https://linustechtips.com/topic/29175-will-this-fan-controller-work-for-me/
Case: Corsair C70 Vengance Gunmental Black
Motherboard: MSI Z87-G43
CPU: Intel i5 4670K
GPU: Nvidia GTX 770 Hopefully the Galaxy card with white PCB
CPU Cooling: Corsair H100i watercooler
Case Cooling: 2 Corsair AF series 120 mm  Fans, and the 3 OEM Corsair fans that came with the case
PSU: Corsair AX 750 Watt Gold Cert PSU Modular
RAM: Corsair Vengance Blue Kit (2x4 GB)
Storage: 1xSSD 180-256 GB (Undecided) + 1x2 TB Seagate HD
Accessories: blue individually sleeved PSU cables, BitFenix Alchemy blue 30 CM LED Strips
Optical: Standard 24x DVD Write/Reader
Well it looks like it will do the job, that fan controller is ugly as hell though.
CPU: Ryzen 5 3600 | Cooler: Stock | RAM: 16GB Hyper Fury X RGB | GPU: RTX 2080 Super FTW3 | Motherboard: Gigabyte Aorus Elite| PSU: Corsair RM850x
Storage: WD SN750 500GB / 850 500GB Samsung Evo /  | CASE: 570X | Display: Dell u2414h  | KEYBOARD: Corsair K70 | MOUSE: Corsair M65
Ugh I know, I'm trying to find a decent looking one I can get for under 30 bucks but I'm not having much luck
I might pick up a Lamptron FC4
