I just bought an MSI Primo 81 tablet, and I can't figure out how to power it on. I charged it, it appears to be almost full when the little battery icon appears when I plug it into the wall, but while I can find the power button, it just won't turn on. Is there something I'm missing, like having to install something from a pc? I am so confused. Any help would be greatly appreciated.
https://linustechtips.com/topic/291689-tablet-wont-power-on/
have you connected it to a PC, if yes, does it show up?. If it doesn't power on then try calling MSI
Planned I Hope Someday I Do First Build: CPU: Intel Core i7 5820k CPU Cooler: CM Hyper 212 EVO Mobo: MSI X99S SLI PLUS RAM: Corsair Vengeance LPX 16GB (4x4GB) DDR4-2133Mhz Storage: Corsair Force LS 240GB SSD & 2TB WD Green Graphics Card: ASUS GTX 970 4GB Turbo Case: NZXT S340 White PSU: EVGA SuperNOVA NEX 750W 80+ OS: Windows 8.1 64-bit OEM Monitor: AOC i2267Fw 60Hz 22" Monitor
https://linustechtips.com/topic/291689-tablet-wont-power-on/#findComment-3961873
I have connected it, but it does not show up.
then call msi  :)
https://linustechtips.com/topic/291689-tablet-wont-power-on/#findComment-3961929
