PSU Extension Set Help
Solved by Dabasepc,
This is custom sleeved extensions sets for "better looking". Take a look at your PSU cables before spending.. EVGA PSU cables are not that bad looking. I have a PSU of this Brand myself and i'm happy with the cables.
You are fine with the custom 24pin to give power to the motherboard and the 2 x 6pin to give power to your graphic card.
You won't see the CPU cable because the connector is at the top of the Mobo.
You have a Corsair 350D with a "small" window, not a side panel with a full window, like this case:
