3.5mm jack L&R Audio switched
Solved by TheKDub,
Worst case scenario you can put the left speakers on the right and vice-versa
Kinda a pain for when I use my headphones as they are made to only fit correctly one way...
I'll just get a 3.5mm male to rca female and vice versa, then just connect the left audio to the right, and right to the left to switch it.
FireLegend ·
Posted in Peripherals1 -
3
5
OzZy15 ·
Posted in Graphics Cards3 -
6
4
17
JustAPcGal ·
Posted in Graphics Cards8 -
Pinto1 ·
Posted in Power Supplies1
play_circle_filled
Latest From Linus Tech Tips:
Why I’ll be Taking VPN Sponsorships Again… and Why I Stopped
