so while stress testing using Kombustor and playing Tomb Raider 2013 my cousins GPU (GTX 660) temps reach a constant and stable 81°C. are those temps normal or should he try and lower the temps?
PROJECT MOGARCPU: i5 4690k @ 4.9 Ghz CPU CoolerCorsair H100i in Pull on top Motherboard: Gigabyte Z97X-Gaming GT GPU: Gigabyte GTX 1080 G1 Gaming Edition RAM: Corsair Dominator Platinum (2x8GB) 2133 Mhz  PSU: EVGA G2 850W SSD: Samsung EVO 840 250 GB HDD: WD Black 1TB Case: Cooler Master CM Storm Scout II
https://linustechtips.com/topic/277539-gtx-660-temps/
It's fine during stress tests.
It will usually not be going that high in game scenarios
well even while playing Tomb Riader 2013 it will reach and stay at 81°C
https://linustechtips.com/topic/277539-gtx-660-temps/#findComment-3765621
That is the default limit set by Nvidia, the GPU clock will throttle down to keep the temperature around 80c. You can try use manual fan control in MSI Afterburner to lower the temp.
https://linustechtips.com/topic/277539-gtx-660-temps/#findComment-3765806
yeah i forgot i could regulate the fan speed in Afterburner :P
https://linustechtips.com/topic/277539-gtx-660-temps/#findComment-3766053
Customize the fan curve and be sure its set to auto. Whats the brand/cooler on the card?
  1. GLaDOS: i5 6600 EVGA GTX 1070 FE EVGA Z170 Stinger Cooler Master GeminS524 V2 With LTT Noctua NFF12 Corsair Vengeance LPX 2x8 GB 3200 MHz Corsair SF450 850 EVO 500 Gb CableMod Widebeam White LED 60cm 2x Asus VN248H-P, Dell 12" G502 Proteus Core Logitech G610 Orion Cherry Brown Logitech Z506 Sennheiser HD 518 MSX
  2. Lenovo Z40 i5-4200U GT 820M 6 GB RAM 840 EVO 120 GB
  3. Moto X4 G.Skill 32 GB Micro SD Spigen Case Project Fi
https://linustechtips.com/topic/277539-gtx-660-temps/#findComment-3766105
Also, if the GPU is old, make sure there is'nt that much dust on the heatsink. (it blocks the air flow.)
i7-5820K | ASUS X99-A | Corsair DDR4 LPX 16 GB | MSI GTX 970 Gaming | Corsair 750D | WD Black 1 TB | MX100 256 GB | EVGA SuperNOVA 750 Watt | ASUS VG248QE | Corsair H105 | K70 MX blues non-RGB | M95 | H1500 | Windows 8.1 64-bit
https://linustechtips.com/topic/277539-gtx-660-temps/#findComment-3767341
