Hello dear comunity im new to here and its the first time I planing building a gaming computer. I did build some desctop computers in school, so I know how to build a computer and have some knowledge in hardware but not deep knowledge.
Usualy I whant to buy a UHD monitor
but I would like to play whitout problems. So I came to the decission to build a computer thats easy to upgrade if GPUs have eneught power to handle UHD whit higer FPS.
If someone could awser me these questions:
- How long until next/powerfull UHD compatible GPUs?
- What should I buy now?
- What will be outdated for the next GPUs.
- Will the 2011-3 CPU cipset least a long time?
- Can I use the old GPU for the HD Monitor, and a other GPU for the UHD upgrade at the same time?
1. Budget & Location
- 3'000 - 4'000 CHF
- Swiss
If you don't know CHF -> http://en.m.wikipedia.org/wiki/Swiss_franc
2. Aim
Gaming Computer
Upgradeable from HD to UHD if GPUs strong eneught.
Games:
- The Witcher 3
- FarCry 4
- GTA 5
- Minecraft
3. Monitors
For now HD (games on best graphik settings).
But I don't know TN or ISP.
Not to expencive.
4. Peripherals
- Keyboard
- Headset
- Windows 8.1
5. Why are you upgrading?
- Not an upgrade.
6. Optional
- Case: NZXT H630
- I dont care about silent or not, just powerfull and cool.
- I could wait 1 or 2 months for GPUs but not more.
I thank inhen in advance for your reply.
https://linustechtips.com/topic/272543-need-help-at-hardware-selection/
