Hey!
I'm looking to install some red led strips into my case and was wondering if I could get some with a breathing effect that you can get on some RGB keyboards? I did some quick looking around and wasn't able to find any!
Any help would be greatly appreciated!
DESORATE
https://linustechtips.com/topic/266011-breathing-red-led-strips/
Desktop: Intel Core i5 2380P (2400 w/o iGPU), MSI H61, 8GB RAM, 256GB SP610, 500GB WD Blue, HIS R9 280, Antec TruePower Classic 550W, Inwin MANA 134, QNIX QX2710, CM QuickFire Rapid, Logitech G402
Laptop: Toshiba Satellite L40D, AMD A6-6310, 6GB RAM, 500GB HDD, Radeon R4 Graphics, 14" 1366x768
Phone: iPhone 6 Space Gray 64GB, T-Mobile $60/mo 3GB plan
https://linustechtips.com/topic/266011-breathing-red-led-strips/#findComment-3614421
https://linustechtips.com/topic/266011-breathing-red-led-strips/#findComment-3614434
Thanks for the reply. I've watched some reviews on these exact strips and unfortunately they can only do the breathing effect on the white colour. :( I can't quite see whether the other remotes linked are different.
https://linustechtips.com/topic/266011-breathing-red-led-strips/#findComment-3614570
This one looks good but I can't get it shipped to Canada unfortunately. Thanks though!
https://linustechtips.com/topic/266011-breathing-red-led-strips/#findComment-3614573
Just browse ebay. Any strip with the controller will be able to do what you want. 99% of these controllers are all the same mass produced product.
Youll have to wire it yourself. Just connect it to the 12v/gnd pins on a molex and your good to go.
https://linustechtips.com/topic/266011-breathing-red-led-strips/#findComment-3614640
