Sorry if this is off topic, but I really need help with this.
So I ran over to Fry's Electronics to grab an Antec HCG-620M to use as a power supply, even if temporarily. This is to replace my old Zalman ZM500-RS which couldn't provide enough power on the 12V rail to power my EVGA GeForce GTX 760 Superclocked ACX. However, new issues popped up. Now, if I try running FurMark power throttling is an issue rather than temperature limits. In addition, there are a ton of FPS drops to 0 in FurMark, usually when I hit 99% TDP. There's also an issue with my In addition to this, I've noticed my room light which is connected to the same outlet as my PC flickers at about the same time my FPS drops in FurMark.
This probably isn't the clearest question, but what is causing my power issue? I've heard about faulty power outlets, but I'm not sure if that's the issue.
PC Specs:
    • CPU
      Intel Pentium G3258 @ 4.0GHz
    • Motherboard
      Gigabyte GA-Z97X-SLI
    • RAM
      Corsair Vengeance 16GB 4x4GB DDR3 @ 1333MHz
    • GPU
    • Case
      Corsair Graphite 230T Red Windowed
    • Storage
      Western Digital Caviar Blue 500GB 7200RPM
    • PSU
      Antec HCG-620M
    • Display(s)
      Dell S2409W 1920x1080, HP vs19 1280x1024
    • Cooling
      Stock Coolers
    • Keyboard
      Microsoft Natural Ergonomic Keyboard 4000
    • Mouse
      Microsoft Arc Touch Mouse - Limited Edition Artist Series - Oh Joy
    • Sound
      Altec Lansing FX4021
    • Operating System
      Windows 10 Technical Preview
https://linustechtips.com/topic/260722-pc-not-getting-enough-power/
normally your pc world crash or restart if it was not getting enough power (worse case the psu would pop).
I would say there is another fault causing your issue.
if you are sure that nothing is overheating then you might want to run memory test, check disk on hdd's
or maybe even try reinstalling windows as it might be a corrupt software/drivers too.
Win 10 Pro 64bit| Intel i5-4670k| Corsair H100i| ASUS Maximus VI GENE| 2x8GB PC3-14900 Corsair Vengeance Pro Red| MSI GeForce GTX 1070 | SanDisk 240GB Extreme Pro SSD| WD 3TB Red | WD Black 3tb | Corsair Obsidian 350D| Corsair AX760 | Dust |
It's the power outlet and it's really easy to troubleshoot...  Go plug your PC into an outlet in a different room in the house, or better yet, do it at a friend's house.  It's highly unlikely to be a HDD or software/driver issue...
"There are 10 types of people in the world: those that understand binary and those that do not."
CPU:  4790K @ 4.7GHz  Motherboard:  ASUS Maximus VI Formula  RAM:  32GB Corsair Vengeance Pro 2400MHz  GPU:  (2) GTX 780 Poseidons in SLI  Case:  NZXT H440  Storage:  (2) Samsung 840 EVO 500GB SSDs and (1) 4TB WD Black HDD  PSU:  EVGA Supernova G2 850w  Cooling:  Custom loop - Koolance 380i CPU block, (built-in waterblocks on GPUs), Alphacool VP655 pump, (1) 360mm XSPC radiator, (1) 240mm XSPC radiator, Bitspower 150 reservoir
if the lights flicker in your house, it usually means that you dont have a good ground, but yeah if you dont have enough power from the outlet the pc should crash or cut off i would think.
CPU: i7 4790k OC'd @ 4.6 ghz COOLER: Corsair H105 (SP 120mm Quiet Edition Fans) MOBO: ASRock Z97 Extreme 6 RAM: Kingston Hyper Fury 16GB (2x8) 1866mhz
SSD: Samsung 840 EVO 250GB HDD: WD Blue 1TB GPU: EVGA GTX 970 FTW 4GB PSU: EVGA Supernova G2 750w 80+ Gold Fully Modular CASE: Fractal Arc Midi R2
OPTICAL DRIVE: Samsung DVD Burner OS: Win 7 64bit   Please do some research of your own before asking questions. Google and Youtube are your friend.
