Both are beautiful, which ever you find more attractive with your case.
Available from 3pm to Midnight Eastern Time (GMT-5). (>'-')> <('-'<) ^(' - ')^ <('-'<) (>'-')> You can't stop the kirby dance.
4770k | Gigabyte GTX 970 Mini | Lian Li PC-TU100B | MSI Z87I 2x8GB G.Skill Sniper | Noctua NH-L9i Silverstone Strider 450W SFX | Windows 10 | 2x 250GB 840 Evo Rad 0 1x 1TB WD 2.5" | 25% gaming, 25% CAD and rendering, and 50% web browsing.
https://linustechtips.com/topic/25431-help-with-motherboard/#findComment-322471
For overclocking, they are about the same, if you want overclocking get gigabytes OC board. but the saber tooth (from what ive been told) runs hotter because of the armor so get the hero imo
i5 3570 | MSI GD-65 Gaming | OCZ Vertex 60gb ssd | WD Green 1TB HDD | NZXT Phantom | TP-Link Wifi card | H100 | 5850
“I snort instant coffee because it’s easier on my nose than cocaine"
https://linustechtips.com/topic/25431-help-with-motherboard/#findComment-322554
For overclocking, the Maximus VI hero should be better, as it is an ROG board and generally ROG boards have better BIOS and caps for overclocking.
It also come with Supreme FX audio, which is better quality audio than the Sabertooth audio.
Main PC: https://ca.pcpartpicker.com/list/FNsFVY
Secondary PC: https://ca.pcpartpicker.com/list/7sv7xY
Former Intel Response Squad Member, May Class.
Member of the LTT Forums since January 3rd, 2013.
https://linustechtips.com/topic/25431-help-with-motherboard/#findComment-323600
