I was following steps to change / customize my windows 7 lock screen
one of the steps was to temporarily rename the authui.dll file found in C/WIndows/System32
unfortunately i got sidetracked by something else and didnt get around to pasting in the new authui.dll for the theme i wanted to install,
and i shut down my laptop before i completed the process
now my laptop boots into windows. but instead of the lock screen it now just shows me a blank black screen with the mouse cursor,
I typed in my password into the blank screen anyways just in case that would boot me into my desktop but it didnt....
I messed up, Im freaking out
Please help me LTTC
Thanks
SOLVED!
I plugged in my laptop's harddrive into my desktop
and was able to go into the Windows/System32 folder and rename the file back to its original name
and now it works once again
*phew*
Phenom II X6 1090T @3.6ghz , EVGA GTX 770 SC, 8GB Hyper-X ram, Adata SX900, WD Black, Corsair HX850, LG IPS234, Logitech G9x, Logitech X-230, Netgear R7000
https://linustechtips.com/topic/249369-help-screwed-up-authuidll/
