Hey guys! I just recently starting using AI Suite and love it so far. The problem is that I watercool, and care more about my gpu temps then my cpu temps. As far as I know, AI Suite only lets you set a fan curve based on your cpu temperature. My radiators are total over so heat won't ever really be a problem. Idk maybe I have temps OCD >.>
Is there any way to make the software read from my GPU instead of my CPU?
https://linustechtips.com/topic/248471-ai-suite-v3-question/
Use speedfan instead?
SimRacer - Casual FSX Pilot!
Mobo: MSI B550 Tomahawk | CPU: Ryzen R5 3600 | GPU: Vega 64 Sapphire Nitro | RAM: 16GB Crucial Ballistix DDR4 3200Mhz | PSU: EVGA P2 1000W 80Plus Platinum | Storage: 256GB Samsung 840 Pro SSD - 1TB WD Black - 2TB Seagate HDD | Cooling: Dark Rock Pro 3, Noiseblocker eLoop Fans | Case: Phanteks Enthoo Luxe | Audio: Sennheiser HD598 - JBL LSR305s | Display: BenQ EX3501R, Asus VG278H
https://linustechtips.com/topic/248471-ai-suite-v3-question/#findComment-3407981
what motherboard? some of the Z97 use an OPT header and TProbe to set
curve from. run TProbe to thermal destination, then set fan curve to that
thermal output. the OPT_FANX header and then there is a twin pin header
used for the TProbe.
https://linustechtips.com/topic/248471-ai-suite-v3-question/#findComment-3408391
