Hard drive not detected
Go to solution Solved by thekeemo,
Currently using windows 8 and I can't find the computer management settings. Is there other way?
control panel --> adminstrative tools --> computer management
So I just completed my first build and I'm having problems on my HDD. It's detected in UEFI but in the My computer, it's not. Do you guys have solution for this one?
Corsair 760T White | Asus X99 Deluxe | Intel i7-5930k @ 4.4ghz | Corsair H110 | G.Skill Ripjawz 2400mhz | Gigabyte GTX 970 Windforce G1 Gaming (1584mhz/8000mhz) | Corsair AX 760w | Samsung 850 pro | WD Black 1TB | IceModz Sleeved Cables | IceModz RGB LED pack
https://linustechtips.com/topic/246115-hard-drive-not-detected/
open computer management --> drives and storage right click on the unallocated space choose format and then it should work
https://linustechtips.com/topic/246115-hard-drive-not-detected/#findComment-3378540
https://linustechtips.com/topic/246115-hard-drive-not-detected/#findComment-3378605
Solved the problem! Thanks for the help!  :D
https://linustechtips.com/topic/246115-hard-drive-not-detected/#findComment-3378648
