600T Clear Side Panel
Go to solution Solved by liveturbo24,
you have to buy the full Acrylic side window from http://www.mnpctech.com/Corsair_600T_Clear_Side_Panels.html . 600T does not come with full side window from Corsair.
Parvum Systems S1.0, 3570K, H100i, Asus Maximus V Gene, Crucial Ballistix Tactical Tracer 16GB @ 1866, EVGA GTX 680 FTW+, Samsung 840 Pro 128GB SSD, WD Velociraptor 600GB HDD, Corsair AX850
https://linustechtips.com/topic/24082-600t-clear-side-panel/#findComment-305388
