haswell ring ratio
Solved by TheRetiredSlave,
Technically it could affect performance, but I don't believe that any tests have shown any significant differences.. Generally speaking, lowering the ring ratio can allow for higher core clocks, and higher core clocks do improve performance.
I believe that a lot of people usually leave ring ratio in the 3.5-4.0 Ghz range when trying to overclock the cores.
Edit: found this thread:
http://linustechtips.com/main/topic/28465-haswell-cpu-ring-ratio-tests-and-results/
To summarize all the results, pushing core clock higher improves performance, while ring clock doesn't seem to really affect much at all..
4.7 Ghz core + 3.0 Ghz ring offers better performance than 4.5 Ghz core + 4.4 Ghz ring in Cinebench.
