Recently I have been having a problem with my computer where it would randomly crash without warning and no BSOD, It was a critical error in the event viewer called Kernel Power Event 41 (63). I have researched alot on this and I havent been able to fix it. I cannot pin point the exact issue. It was said to be something to do with the PSU
In the event viewer it has come up with this problem in the details
- System
    - Provider
      [ Name] Microsoft-Windows-Kernel-Power       [ Guid] {331C3B3A-2005-44C2-AC5E-77220C37D6B4}
      EventID 41       Version 2       Level 1       Task 63       Opcode 0       Keywords 0x8000000000000002     - TimeCreated
      [ SystemTime] 2014-08-10T18:29:21.431206900Z
      EventRecordID 90007       Correlation     - Execution
      [ ProcessID] 4       [ ThreadID] 8
      Channel System       Computer Myron1-PC     - Security
      [ UserID] S-1-5-18
- EventData
    BugcheckCode 0     BugcheckParameter1 0x0     BugcheckParameter2 0x0     BugcheckParameter3 0x0     BugcheckParameter4 0x0     SleepInProgress false     PowerButtonTimestamp 130521426576796395
I have tried alot of things to fix this. The image I have attached was when it first started doing this. It has gotten more recent and happens alot more often than it used to. I have tried reverting my GeForce drivers back because I installed them around the date that it started happening. This has caused it not to do it while playing some games. But it still does it. Someone on a fourm said it was an ATI Audio collision causing it to crash and so I disabled the other audio devices in the device manager and this has also not done anything. It has been really hard to pinpoint what the problem is and I still think its my PSU being faulty. I dont want to buy a new PSU and for it to not fix.
My PC specs are:
ASUS Sabertooth 990fx 2.0
AMD FX8350
Gigabyte Nvidia 660 Ti 2GB
8GB of standard RAM.
GX lite 600w PSU
I tested my ram and it was ok with no errors.
post-153562-0-20421100-1414078969_thumb.
https://linustechtips.com/topic/237768-kernel-power-event-41-63/
