hello. im making my first PC and well. i dont know much. ive got all the parts but the motherboard because i screwed up with that and had to return it. will this motherboard be ENTIRELY compatible with my build?
http://www.asus.com/Motherboards/A88XMA/specifications/
my build : http://au.pcpartpicker.com/p/HCWjvK
also i have a graphics card and a wireless adapter also.
https://linustechtips.com/topic/235261-motherboard-compatible-with-build/
If you have a GPU you may need a more powerful PSU but I can't say without knowing what GPU you have. Look at Corsair's CX500. A lot more power for about the same money.
Unless the GPU you have is capable of dual graphics with the APU, you're better off getting an Athlon X4 CPU for less money or a Pentium G3258, also for less money.
If this is for gaming I strongly suggest an H97 board and a G3258.
Intel Inside. Overweight guy in his 30's outside.
my gpu will work with my psu here it is. i didnt want to link it because it always changes the topic. ive got all the parts already exept the motherboard  http://www.ebay.com.au/itm/GIGABYTE-GT630-2GB-Gaming-Video-Card-nVIDIA-GeForce-Graphic-2048MB-HDMI-DVI-VGA-/230834429032?pt=AU_Components&hash=item35becddc68
