My google chrome start to pop up this. When i look up online, i didn't find any solutions. I try to re-install the google chrome but after couple of days, it's back.
But when I started windows up and signed in and i got this error.
Script: C:\Users\...........\Appdata\Local\Google\Chrome\User Data\Default\Extensions\lod1.vps
Line: 7
Char: 5
Error: The server name or address could not be resolved
Code: 80072EE7
Source: msxml6.dll
And
C:\Windows\SysWOW64\Cmd.exe came up too
A subdirectory or file c:\a\already exists.
A subdirectory or file C:Users\........\Appdata\Local\Google\Chrome\User Data\Default\Extensions\hcnoocjdgpaeliplnkbhbpccighjkeef\ already exists.
A subdirectory or file C:Users\..........\Appdata\Local\Google\Chrome\User Data\Default\Extensions\hcnoocjdgpaeliplnkbhbpccighjkeef\\3.2_0 already exists.
1 file(s) copied.
1 file(s) copied.
https://linustechtips.com/topic/23306-i-have-this-problem-for-long-time/
Going to need to run a good malware and virus removal tool. FROM a BOOT DISK..try this here https://support.kaspersky.com/viruses/rescuedisk
The last entry is NOT valid : GO her to read about the issue: http://www.drwebhk.com/en/virus_techinfo/Trojan.KillProc.22390.html
Clear Chrome of ALL your extensions..
Your best effort is the easiest thing to give to someone else..
Well the entry you list IS from a malware infection..Trojan.KillProc.22390..SO something is not right..
You can use Nortons
http://security.symantec.com/nbrt/nbrt.aspx
Just follow the instruction from Nortons . It will explain how to use it . You will need to boot directly into the scanner/repair tool for some malware to be seen and removed. Following this link will explain what you have and what it does on your system.The site also has a removal tool as well.
Well there is ..If you do not have a current valid Norton's Product Key..then they have a free removal tool here. http://security.symantec.com/nbrt/npe.aspx?lcid=1033
I do not know about the DrWeb..only that it matched your entries :
A subdirectory or file C:Users\..........\Appdata\Local\Google\Chrome\User Data\Default\Extensions\hcnoocjdgpaeliplnkbhbpccighjkeef\\3.2_0 already exists."
It is this entry and ALL entries with these types of directories which tell you that you have a problem : "\hcnoocjdgpaeliplnkbhbpccighjkeef\"
 I will say that the issues that you have posted about returned a error which indicated a malware infection..and the best way to rid yourself of these is to use a bootable removal tool
I hope that you can use the Nortons or the free Kaspersky boot tools to get rid of them..Good luck.
  • 4 weeks later...
Hey Jackson, were you able to resolve the problem?  If not when all else fails, just use a windows operating system disc to just start fresh.  Wipe that storage o.s. drive clean, and start over, but if possible FIRST back up your typical media:  documents, pictures, videos, movies, and installation exe files  to a SEPARATE storage device ( another internal hdd or external hdd).
Reinstall all of them FRESH after you perform a clean ( aka  CUSTOM ) install of the o.s and make sure your physical ethernet aka Lan driver is working so you can get online and update windows.
I've used Norton, McAfee, Kaspersky, Bit Defender, AVG, damn near everyone in existence and I can tell you from experience...NO antivirus is perfect and foolproof.  If you visit the correct url at the right day...you'll get a virus or worm that none of these idiotic wastes of time and/or money can prevent from infecting your system.
This is why I STOPPED dealing with antivirus altogether let paid subscription antivirus programs.  It's a waste of money and time.  It's not the same as if you're a billionnare living in a decent house and you want a good security company to monitor your home.  YOUR LIFE  physically is much more important than a pc.  You can't replace your life, but you can EASILY replace your o.s., programs, and files back to the way things were.  It just takes time and the more practice you get doing either of the two methods I mention, the quicker you'll LAUGH at the fear of getting a virus.
LEARN how to back up your data and installation exe files(so you can reinstall all your programs and games) so you can do a REAL cleaning of your pc that is GUARANTEED to wipe out any virusus you encounter.  Or have a big enough separate storage device ( hdd or ssd doesn't matter either way) that you can create an IMAGE backup of your entire system, then use Windows o.s. disc to wipe the o.s. storage drive clean and restore the image.  This is MUCH quicker often than the more "manual" way that I mentioned.
Not trying to put words in your mouth, just thinking out loud.  HOpe this all helps
Hitman Pro is a free to use for 30 days anti-DAMN NEAR-EVERYTHING program that can destroy the FBI dot green moneypak virus that usually basically cripples anyone's pc.
I'd try that.  here's a url to help http://www.malwareremovalguides.info/remove-fbi-virus-using-hitmanpro-kickstart-instructions/
I'm sure if there is malware or coherent problems on your pc.  this should help if it's good enough to remove that nasty fbi monekypak virus which really is just hardcore malware that takes over explorer.exe and other deeper parts of the O.S.'s running GUI involved dlls.
