http://pcpartpicker.com/p/BqCVf7
I already bought all my parts which cpu would be a better value within a 60 to 80 dollar range with the fm2 socket as I don't want to get a new motherboard and if you suggest a CPU would i be able to play most games on at least low settings?
https://linustechtips.com/topic/224084-low-end-budget-pc-cpu-help/
Having a gpu for playing games is EXTREMELY helpful. If you can't get a gpu then the A-10 series of APU's from AMD is pretty good but those are out of your price range. I don't have any experience with other APU's but apart from that if u get a non APU cpu your not gonna really be able to play games ( unless it's like minecraft or something non intensive) of the integrated gpu.
Written on my Lenovo Z500 T - I5-3230M   Or
My pc :)
 If you are asking for an APU/CPU suggestion going up 60 to 80 dollars, then the A10 5800k @100.00 or the A10 6800K @ 125.00.  If going those amounts lower....not sure. Ahh...saw the "value" portion in your post. Would have to agree with Feronix on the 760K, but then you have to add in GPU.
Case: Silverstone SG09B Motherboard: MSI Z10 Morter M-ATX CPU: I5-6600K  Ram: Corsair LP 2400 DD4 16GB GPU: MSI RX 480 Storage: Seagate HDD Baracuda 2TB x2, Crucial M200 500GB SSD X2 (Raid 0)PSU: Silverstone Strider Gold 1000W w/PP05E Kit
"When to say :blink: WTF :blink: ....$2K rig only used for Minesweeper and Internet Checkers marathons...."
The Athlon 760k is a proper value CPU that fits the AM2 socket, but it has no integrated graphics and you'll need a GPU to go with it.
FM2*
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
