I have a question.
I have a Lenovo G405S(14-inch) equipped with an A10-5750M+HD8650G and HD8570M.
Do i use the crossfire functions , as in , the 8650G+8570M , or do i just use the 8570m?
Certain games did not detect my 8570M even when i put it into High-Performance and disabling dual-graphics.
*Specs Note(Just in case) :
A10-5750M based at 2.5 ghz , turbo at 3.5(couldnt achieve this , dunno why) , though i can clock-lock my cpu at 3.2ghz but that would bring the heat up to 100degrees.
8GB(4x2) DDR3 1333mhz
HD8650G is 768MB DDR3 128bit , 8 ROPs 48 TMU , 5.8GPixel/s 34.6GTexel/s , 21.3GB/s (Bandwidth) , base gpu-clock at 720mhz and base mem-clock at 667mhz.(Based on RAM , i have 8gbs DDR3 1333mhz).
HD8570M is 2GB GDDR3 128bit , 8 ROPs 24 TMU , 6.6GPixel/s 19.8GTexel/s , 28.8GB/s (Bandwidth) , base gpu-clock at 825mhz and base mem-clock at 900mhz..
Screen Resolution at 1366x768.
https://linustechtips.com/topic/220155-help-on-dual-graphics/
