Hi!, im "new" to pc gaming (i played on scrappy laptop for a while), and i want some help on overclocking my FX-8350.
I used amd overdrive to overclock it from 4.0GHz to 4.1GHz , tested it and it was stable (i've been using it for weeks and it has had no problems either), but when i push it to 4.2GHz and test it (1Hr test) it says it's unstable, have i reached the limit on my CPU or can i push it to 4.3GHz and it might be stable.
Thank you in Advance!
https://linustechtips.com/topic/219529-fx-8350-overclocking-help/
Corsair 750D | Asus Crosshair V Formula-Z | FX 9590 | Kingston HyperX 16GB@1866MHz | MSI R9 290X Lightning | Seasonic 1050W Platinum | 2x WD 3TB Green HDD | Samsung 840 Pro 256GB SSD | Crucial 512GB SSD
Alphacool XT45 360mm | Alphacool Monsta 280mm | Silverstone AP121 | Silverstone AP141 | EK Supremacy Elite | EK ASUS C5F-Z | EK R9-290X Lightning | EK 3/8-1/2 Nickel | XSPC D5 Acrylic Tank | Primochill 3/8-1/2
Another factor may be your motherboard.  A bad overclocking mobo will not be able to deliver adequate power above stock speeds...  Or you did bad in the silicon lottery.  Are you increasing the voltage at all?
i5 4670k (can OC to 4.4Ghz) - Hyper 212 evo w/ AC MX2 - XFX Radeon R9 280X8GB ADATA XPG V2 DDR3-1600 - MSI Z87 G41 - Corsair CX600M 600W PSU - 1TB HDD - 120GB SSD
welcome to the Linus Tech Tips forums!
build specs would be nice to know.
are you trying to overclock on the stock air cooler of the 8350?
what level adjustments have you made to get 4.1 and 4.2GHz?
Dont use overdrive for overclocking.
BUt overclock directly from the bios.
You could overclock on 2 diffrent methods, using multiplier or Northbridge overclocking.
Which mobo do you have?
Northbridge overclocking:
Multiplier overclocking:
