i have shaw 25 mb internet plan and i am using linksy ea2700, i use Asus Wireless N PCI E adapter(PCE N15) but my internet is really slow. help plz.
product (http://store-ca.linksys.com/en-ca/Routers/Linksys-EA2700-DualBand-N600-Router-With-Gigabit_stcVVproductId145518153VVviewprod.htm?icid=en-ca-products-family-linksys-ea2700-image )
(http://www.asus.com/ca-en/Networking/PCEN15/)
post-53218-0-35723100-1410989287_thumb.j
https://linustechtips.com/topic/217110-internet-speed-really-slow/
What provider are you with? What speed are you paying for?   I need to learn to read. Run a speedtest here: http://speedtest.net
Case: Phanteks Enthoo Pro | PSU: Enermax Revolution87+ 850W | Motherboard: MSI Z97 MPOWER MAX AC | GPU 1: MSI R9 290X Lightning | CPU: Intel Core i7 4790k | SSD: Samsung SM951 128GB M.2 | HDDs: 2x 3TB WD Black (RAID1) | CPU Cooler: Silverstone Heligon HE01 | RAM: 4 x 4GB Team Group 1600Mhz
I get these results on speed test but when I go on Steam and download something is always on 1 megabyte and sometimes I can't even watch twitch on high
Wi-Fi is sometimes hit and miss on speeds.  Is it possible for you to get a wired connection on your PC and run a speed test with that?
Forgot to mention, your ISP and the speedtest measures your speed in Mbps (megaBITS per second) and when you download or stream you will probably get a measurement in MB/s (megaBYTES per second).  This numbers will be very different.  To convert megabits to megabytes divide the number of megabits by 8.
I cannot get a wired connection since the router is on the top floor
Do you maybe have a laptop, tablet, or other device that you could do a speed test on?  If you could do a speed test on a wired connection and you get the same results then you need to contact your ISP because you're not getting the speeds you pay for.  If a laptop, phone, or tablet can connect to your Wi-Fi and get a full 25Mbps download speed then the problem lies in the connection between your PC and router.
