Speaker problems Not sounded right
What sound are you playing there?
Can't you upload one with music?
im playing the windows audio sound.
heres the only other footage i have
https://www.youtube.com/watch?v=G3c61yChUuw
im taking them apart now, to see if maybe a wire or the glue has gone bad.
It think it sounds like the Parts that separate the frequency are broken.
I only know the German expression. (Frequenzweiche)
So the mid-bass speaker trys to play the high frequency's and that results in a bad sound.
Did you try different audio sources?
Another thing could be that you had an over load on a speaker and its voice coil melted. You can test it if you push the membrane of the speakers back (with your fingers) if it makes a scratchy noise that will be it.
ok thx, i call it a filter..probably wrong term but oh well
