Corsair K70 problems
Go to solution Solved by IBIubbleTea,
Hey everyone, today, I got a Corsair K70, but when I started using it, it made my PC randomly freeze. It is the keyboard because this has never happened before. Does anyone know how to fix this I really don't want to have to ship this back. Thanks everyone
Have you tried using the keyboard on a different computer? What setting do you have the keyboard on? Also update that firmware!
You must "Quote" to get my attention​.
 ~IBIubbleTea - 20/07/2014
https://linustechtips.com/topic/213397-corsair-k70-problems/#findComment-2911538
I dont have another computer to try it on, and currently its on the 8 setting, and I cant update the firmware because the keyboard freezes everything before I can launch it
https://linustechtips.com/topic/213397-corsair-k70-problems/#findComment-2911578
Have you tried using it on a different setting?
https://linustechtips.com/topic/213397-corsair-k70-problems/#findComment-2911711
I am going to right now, if I don't answer anyone back right away it's because it froze again
Looks like you froze. Try using a different USB port and maybe even try updating your BIOS. Also make sure you both the USB plugged in in a USB 2.0 port.
Welp.~~~~
https://linustechtips.com/topic/213397-corsair-k70-problems/#findComment-2911914
Alright, I got the firmware updated, so far so good, is there any other precautions I should start taking 'or anything just incase this goes to shit?
Dont touch anything, don't have anything plugged into the keyboard, and don't turn the computer off.
https://linustechtips.com/topic/213397-corsair-k70-problems/#findComment-2911939
I had an issue with it so want I did is I change the response time
everything ever since I had no issues
so flip the switch one over and you're golden
https://linustechtips.com/topic/213397-corsair-k70-problems/#findComment-2911940
