Hey guys
I feel like a total noob asking this but..
I'm in the market for a dual rad(?) closed cpu cooler (ie: CoolerMaster Nepton 280L or Corsair Hydro Series H110). I want to place it on the top of my CM Storm Trooper case, but it doesnt seem to be heaps of room between my MB and the top of the case.
I was wandering if someone could suggest a CPU cooler that would actually fit.
For the record i have a GB x79-UP4 32gb kingston hyperx ram and a i7-3820
I know i can have on down the bottom but im using the ssd cage
Thanks guys
CPU : i7 5820k l MB : ASRock Fatal1ty X99M KILLER/3.1 l RAM : 64GB l GPUs : GTX 970 l Case : Corsair 350D l SSD 2x250gb HDD 2x3tb Raid0 l CS750M PSU
CPU : i7 920 l MB : Gigabyte GA-Ex58-UD5 l RAM : 24 GB  l Case : CoolerMaster Silencio l 3x3TB Raid 5 l  Corsair VS650 | ESXI 5.5
Asus G551VW | i7 6700HQ | 32 GB | GTX 960M | 500 GB Samsung mSata | 1TB WD
https://linustechtips.com/topic/200254-cpu-cooling-for-cm-storm/
Looks like the case can only fit a single rad in the back. You could get away with one of these at the back: http://www.pccasegear.com/index.php?main_page=product_info&cPath=207_23&products_id=22315&zenid=33e89d6268b4dd29dab7196e4a Although I know this isn't Ideal for you as you want it out of the way?
Ola Englund does not approve of your hashtags. Sleep is for the weak, insomnia builds character.
As you are reading this you are slowly traveling forwards in time to where you will get out of the time machine and continue to read posts. Too spookyfor100me.
https://linustechtips.com/topic/200254-cpu-cooling-for-cm-storm/#findComment-2714443
