Router Help and suggestions!
It's said that wifi routers find it easier to supply good signal below thair position than above it. Try the thing upstairs, see who complains their wifi is worse, if no one, job done... Or fit it to the highest point it can go in the room it's in now i.e. right up against the ceiling.
Make one or two aeriels point at right angles to your preferred upstairs spot - pointing AT your preferred spot is wrong.
What are the walls/floors made of? I have tin-foil-like insulation between one of our wifi routers and our main living area and it's unusable.
Take notes on performance then hard reset. Take notes again. Factory reset and reconfig is also on the list of things to do before you spend any money.
Update firmware after a battery of tests then do the tests again. Networks are sometimes hard to set up nicely.
If all fails, run a cable. In fact... run a cable.
